After 386.4 upgrade from 386.3_2 (using current config) the WAN does not connect anymore.
Downgrading to 386.3_2, resetting the config and upgrading again to 386.4_0, the WAN connects correctly with the base 384._0 config.
When applying to 384_0 the 386.3_2 saconfig, the WAN does not connect anymore.
After searching the 384._0 change log, I can't identify the WAN parameter causing the problem.
Please help.
Please help.
