WAN IPv6 gateway problem [fix]
j-p-l
As mentioned in the post below, my WAN IPv6 gateway was not set with Native with DHCP-PD enabled. I was able to interim fix this issue by adding a WAN-startup-script, to manually add the gateway.
#!/bin/sh
ip route add default via fe80::1 dev eth0
@RMerlin, the nvram variable "ipv6_gateway=fe80::1" was already correct, but the route is not set. Maybe there is a possible fix, to set the default gateway without setting a custom startup script?
IPv6 is not working as expected. LAN traffic okay, but no WAN connection. This is not completely new to me - have it since a couple of versions, but it did work - but not fixed in current release. Is this an asuswrt (Merlin) issue, or is it my provider (Vodafone cable Germany, static IPv4/IPv6 dual stack).
I have "Native with DHCP-PD" enabled and receive everything correctly but there is no "IPv6 WAN Gateway". Any ideas?
View attachment 15330 View attachment 15331
fe80: is a link-local IP, it's not a public/WAN IP.
#!/bin/sh
#!/bin/sh
This issue is very similar to mine, there are bugs in the official firmware, it's not a merlin bug,
Here I describe my issue:
https://www.snbforums.com/threads/a...384-45149-12-05-2018.50232/page-6#post-457071
