danjackson
Hi all,
I have the AC88U with latest Merlin. Currently, I send the WAN and LAN output from the Router into a switch (Microtik) which tags the VLAN's on the ports, sends it along another single port trunked to another switch. At this second switch the WAN and LAN is separated into a modem and more LAN ports respectively.
Is there a way to do this on ASUSWRT Merlin so that I can send LAN traffic on one VLAN and WAN traffic on another VLAN from the same port (preferably the WAN port but one of the others will also do).
Obviously this Router isn't designed to do this but given that the firmware gives me pretty much root access via SSH surely there's some way to get this to work even if its non persistent?
Thanks in advance
EDIT:
Might also be worth mentioning that I'm using PPPoE on the WAN port. So I'm looking to send PPPoE traffic tagged on VLAN x and LAN traffic tagged on VLAN y from the same port
Thanks in advance
EDIT:
