WAN status shows as Disconnected when Connected to a VPN
xiaokai
Hi
I am using an AC3200 with 384.6.
I also connect it to NordVPN.
When the NordVPN is connected, the WAN satus on the router shows as disconnected. And on my mobile device, it thinks that there is no internet connection and shows a small x next to the WiFi stating, Connected, No Internet. However the internet on the TV and PCs works fine.
Is there any solution to this?
Thnaks
X
Sorry, I thought you were saying that it was just a cosmetic bug.
Is it only that one phone that is effected? Have you verified that it is indeed using mobile data instead of WiFi?
