WAN/WLAN slower than LAN/WLAN on RT-AC68U
EnfermeraSexy
Hello! i've got this router yesterday and finally got it "perfectly" configured. I've got a 400 Mbps symmetric net in my house, but i can't get the full speed through wlan. I'm getting about 320-330 Mbps of download, but if i transfer something from my computer connected over ethernet to my phone, i can see speeds over 500 Mbps.
What could it be? CPU isn't near to 100%
I saw that thread, but it didn't help me. First i have to say that i can get full speed through ethernet (400), but not over wifi. Yes, it could be that my phone/router can't reach that speed but i can get over 500 Mbps in LAN-to-WLAN transfers!
My actual firmware is Merlin 384.4_2, i've got QoS disabled, firewall disabled and aiprotect disabled, everything is disabled.
CTF is enabled but i can't get FA enabled, anyway i read somewhere that AC68U don't have it.
Thanks for your reply :)
Why? I always did it on the Asus routers because the first one I had made internet browsing slower with it enabled
Then I hope you won't be coming here asking for help when your router is taken over by a botnet.
That firewall is there for a reason.
:eek:
The router's firewall is your first and most important layer of protection from unsolicited attempts to gain access to your network.
https://www.snbforums.com/threads/enable-firewall.40307/#post-337357
Enabling the firewall should not have any effect on browsing speed. If you're experiencing that then there is a problem elsewhere.
The only time you would turn off the firewall is when the network connected to the WAN interface is not a public network. Such a setup might be when the router is being used in a corporate environment.
