Warnings on Router Logs
RouterQuestions25
Don’t have much understanding of networking as such however just got a new router and was checking the logs to ensure nothing stood out to me, however have a lot of:
wl1: dhd_prot_ioctl: status ret value is -23 iov=mbo
Warnings and just wanted to make sure it was nothing to worry about, if it is what is it and how can it be fixed?
Are the logs separated by function or part of the router ( modem, wireless, lan, etc ) ? If so which section is this appearing in ?
If not -
Is the time interval between messages roughly constant ?
Turn off wireless radios for a while, longer than the time interval. Did it go away ?
If it did, turn off 2.4GHz radio for a while - did it go away ? Do same for 5/6 GHz radios.
it could be something as simple as an IOT device trying to talk with the router wireless Access Point section.
You may have to ask level 2 tech support from your ISP.
It is most likely nothing to be concerned about and from some wireless issue.
