WD My Book World Edition II 4Tb
sranger
Hello,
First, let me say this is a great site. I did a lot of research here before I made my purchase.
I purchased a WD My Book World Edition II 4Tb NAS from Amazon ( $488.00 ) and installed it yesterday. It is not the fastest NAS, but seemed to be a reasonable compromise between speed and cost. I tested some file transfer speeds and it seems to more or less match the speeds listed in the NAS charts on this site. I am using an 8 port D-Link DGS-2208 GigaBit switch. I have a Macbook Pro and a Mac Mini ( used as media computer ) I have the 9000 Jumbo frames enabled on both macs. I have two other XP computers and they worked correctly with the new NAS as well.
My old NAS system was a pair of 320Gb Iomega USB drives attached to my USR 8200 VPN router ( Yea I still love the old gal ) so even though the WD NAS it is not up to the speed of the more expensive units it was a significant boost in transfer speed from my old system. I also needed to store files larger than what FAT32 can handle ( FAT & FAT32 are the only options in the old USR 8200 ) I am running it as a RAID 1 and will get a 2Tb USB drive to backup the WD NAS.
I was happy to see that there was a new firmware available that adds Apple Time Machine compatibility. I chose the auto firmware update in the WEB interface and it worked without a hitch. The two macs and Time Machine worked flawlessly with the WD. The new Firmware also allows for unattended downloads as well. No scheduled backups yet, but at least it added a few options.
I have a medium size mp3 music library and I put it on the NAS and enabled the iTune media severs and I could see it on the Macbook and Mini immediately. I was disappointed in that it did not seem to understand my m3u playlists I have in the shared music directory. The nNAS uses the Twonky media server 5.1 and after looking at their site, it may be a problem with this version of the server.
I anyone knows of a fix for the playlist, please let me know....
Anyway, I wanted to share my experience say thank for a great site...:D
Hi, Just reading your post and am very interested as I'm trying to sort out my home library. Sorry if you saw the reply and were hoping for a fix.
Jut wondering if, with the iTunes server installed, you can now stream music and video to other Macs? I have an Apple TV, but the library is currently held on a Drobo connected to my iMac which means the Mac has to be on for the ATV to see the library. If I could find a NAS which had a built-in iTunes library, I wouldn't have to keep the Mac on and in the past I've been very pleased with WD My Books.
Thanks in advance for any advice.
It does stream the music, the problem is that you can only see it as a share on iTunes and all of the music shows up as one big list and you can't create a play lists from that shared library.
iTunes stubbornly does not want to let you use a network drive as a shared library, but it is possible to set iTunes up to use a networked drive, but it is a bit of a pain to configure.
I have the Mac Mini as my media computer. As for video, I just play the movies I have in my library with Quicktime from the NAS. It seems to work fine.
As a test for you, I aded a movie to my iTunes library ( without copying it to the local drive ) and as long as I keep the network share open it shows up in FrontRow as an iTunes movie, so I suspect it will work with Apply TV as well. However, since I don't have Apple TV, so I don't know for sure if it will work.
The unit use the Twonky media server, you can read more about it here:
http://www.twonkyvision.de/
