I have an RT-AC66U and a RT-N66U.
My main router is the RT-AC66U.
I want to extend my wireless network and am trying to choose between WDS vs repeater mode. I have a few questions regarding this:
1) From what I see it appears that repeater mode does not create a real bridge but rather a pseudo-bridge (clients behind the bridge use MAC of bridge itself to communicate with anything outside bridge, among other things). Can someone confirm this?
2) My understanding is that since both routers use broadcom chipsets it should be possible to implement WET mode, which my understanding is would create a real bridge (even though it appears to have some caveats). Is this a limitation of the hardware or does the firmware simply not implement it?
3) I currently have my RT-N66U setup as a repeater and am able to get 45mb/s download speeds off the internet on computers behind the bridge (my connection is 50mb/s). However, when sending files from a computer outside the bridge to a computer inside the bridge the speed drops to about 25mb/s. Both computers are connected via ethernet cables so it has nothing to do with distance from the router, can someone explain why this happens?
4) Lastly, and more importantly, ignoring the fact that in WDS (at least using Asuswrt or Asuswrt-Merlin) you can only use WEP, are there any advantages of using WDS over repeater mode? Would my throughput increase if I were to use WDS instead?
Thank you in advance
