Web browsing logs
AbelR1975
I have an Asus RT-AC68U and I am trying to monitor web browsing by ip address. I've seen in Adaptive QoS -> Web browsing, that the router does monitor browsing by device. The problem is that this log is limited to 50 entries per device, then they start getting pushed off. I can't find a way to increase this log or have it save somewhere. I have tried using WallWatcher, but for some reason, the source ip is showing up as my public IP, not the internal device ip. Is there any way to do what I'm looking for? I thought with Merlin, that the traffic history would also save the browsing history as well, but it doesn't appear to be doing that.
Don't think you can increase/modify/delete the web browsing history. However you can try enabling the traffic analyzer option to check for the websites visited and data downloaded. I think it's a hidden link on this model(Not sure cuz I don't have 68u) but you can try to see if it can be accessed at
http://192.168.1.1/TrafficAnalyzer_Statistic.asp
Thank you for your reply. The traffic analyzer is enabled, but it doesn't show the URL like the web browsing tab does in the AdaptiveQOS section.
