Web GUI is not working
ttc0419
After I changed the Web GUI to HTTPS and reboot the router. I cannot access the Web GUI anymore. But I have SSH access. I tried restart the https service by
Bash:
service restart_httpd
, but it's not working. The process is listening on 8443 according to netstat:
admin@RT-AC86U-BC68:/tmp/home/root# netstat -ltn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:5152            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5473            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:18017           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:3394            0.0.0.0:*               LISTEN
tcp        0      0 192.168.86.1:515        0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:47753         0.0.0.0:*               LISTEN
tcp        0      0 192.168.86.1:9100       0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:7788            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:80            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN
tcp        0      0 192.168.86.1:53         0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:8888          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:8443          0.0.0.0:*               LISTEN
tcp        0      0 192.168.86.1:8443       0.0.0.0:*               LISTEN
tcp        0      0 192.168.86.1:3838       0.0.0.0:*               LISTEN
tcp        0      0 :::22                   :::*                    LISTEN
But it does not reply with valid http response even using curl on the router:
admin@RT-AC86U-BC68:/tmp/home/root# curl 192.168.86.1:8443
curl: (52) Empty reply from server
Is there any way I can set web back to http only using command line?
Sorry, no idea. I have both HTTP and HTTPS enabled as well as SSH.
None of these ports are exposed to the internet, they're LAN only. If you're restricting access by IP address that might be an issue.
