I currently have an AC3100 that covers about 85% of my house. There are 2 home offices w/ multiple VoIP lines. I have Spectrum highspeed and get 300mbps wired and mid 150's wireless in most areas. However, wireless gets really sketchy in a few areas and only works "sometimes."
Most of the TV media runs fine . I think I just need to expand the footprint.
I've been wanting to try the AIMesh for a year now.
I would like to keep the investment under $350.
Options:
Do I just keep the 3100 as is, and buy an 86u and add that as a node? Or use the 86u as the main router and turn the 3100 into the node?
Do I buy (2) 86u's w/ the Microcenter deal? If I do this, is the 3100 still worth having on the network?
I can also buy (1) AX88u?
Since I can write this off, I could even swing the 5300.
Is there something completely different I should look at?
Thanks for the input.
Options:
