Hi all
I'm new to this firmware so forgive me if I'm asking stupid questions.
I installed the 380.67 Beta3 firmware on my AC68U (Rev. A1) with no problems and all seems to work and good performance.
I would like to install some of the blocking scripts, but do they overlap or should I just install them all ?
Primarily I want to block outside and in (Bots and other probing attacks). Second blocking for ads and malicious sites inside and out.
I have looked at these scripts:
Skynet (Block. from inside or outside or both?)
iblocklist-loader (Block. from inside or outside or both?)
AB_Solution (Ad blocking from inside)
ya-malware-block (Ad blocking from inside)
Maybe I just need Skynet and AB_Solution ?
I have a little problem finding out what actually to use, they all seem very good, but maybe they block the same things ?
Best regards
Henrik
Best regards
Henrik
