What cause problem when install Entware?
ac66ub1
=> Please enter partition number or 0 to exit
[0-1]: 1
Info: /tmp/mnt/sda1 selected.
Info: Creating /tmp/mnt/sda1/entware folder...
Info: Creating /tmp/opt symlink...
Info: Creating /jffs scripts backup...
tar: /jffs/scripts/*: No such file or directory
tar: error exit delayed from previous errors
Info: Modifying start scripts...
/usr/sbin/entware-setup.sh: line 115: can't create /jffs/scripts/services-start: nonexistent directory
chmod: /jffs/scripts/services-start: No such file or directory
/usr/sbin/entware-setup.sh: line 133: can't create /jffs/scripts/services-stop: nonexistent directory
chmod: /jffs/scripts/services-stop: No such file or directory
/usr/sbin/entware-setup.sh: line 140: can't create /jffs/scripts/post-mount: nonexistent directory
sed: /jffs/scripts/post-mount: No such file or directory
chmod: /jffs/scripts/post-mount: No such file or directory
Info: Checking for prerequisites and creating folders...
Warning: Folder /opt exists!
When I install Entware,
1.I notice "error exit delayed from previous errors", is that means my jffs not format before installation?
2.Is there '/jffs/scripts' folder before Entware installation?
3.How to judge whether JFFS has hardware problem?
[0-1]: 1
Did you enable jffs custom scripts in Adminsitration -> System ?
One other thought, I had to format a USB flash drive to Ext2 and then install to that device. Is that what you have done?
How about reformatting jffs and starting again from scratch?
