Hello everyone,
Earlier today I received my new AX86U that replaces my AC86U. Now, after setting up WG client (Surfshark VPN), I am seeing the following syslogs which I think are related to my WG configuration. The WG client binds my AppleTV which I use for streaming and earlier I noticed that the AppleTV 'loses' internet connection e.g. streaming stops, speedtest app no longer finds nearby servers, although the WG client in VPNFusion shows as connected.
I am running AsusWRT 3.0.0.4.388_21709-g74151b7
I am new to WG client connection as I have only ever used OpenVPN before but I am hoping that you can help me on this.
Nov 30 13:48:33 rc_service: httpds 3418:notify_rc stop_vpnc
Nov 30 13:48:44 rc_service: httpds 3418:notify_rc restart_vpnc_dev_policy
Nov 30 13:48:56 WG: Unsupport: [^M ]
Nov 30 13:49:15 rc_service: httpds 3418:notify_rc restart_vpnc;restart_default_wan;
Nov 30 13:49:17 kernel: blog_link:overwriting ct_p=ffffffc0240bde20, new_ct=ffffffc024411330 idx=0
Nov 30 13:49:17 kernel: NFCT: ct<0xffffffc0240bde20>, master<0x (null)>
Nov 30 13:49:17 kernel: F_NAT<ffffffc02ce1f3f8> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:17 kernel: help<0x (null)> helper<NONE> status=8000018e refcnt=3 zone=0
Nov 30 13:49:17 kernel: tuple ffffffc0240bdeb8: 17 100.64.21.243:50510 -> 89.37.173.43:51820
Nov 30 13:49:17 kernel: tuple ffffffc0240bdef0: 17 89.37.173.43:51820 -> 100.64.21.243:50510
Nov 30 13:49:17 kernel: STATUS[ IPS_SEEN_REPLY_BIT IPS_ASSURED_BIT IPS_CONFIRMED_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
Nov 30 13:49:17 kernel: NFCT: ct<0xffffffc024411330>, master<0x (null)>
Nov 30 13:49:17 kernel: F_NAT<ffffffc02cfebc78> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:17 kernel: help<0x (null)> helper<NONE> status=80000198 refcnt=2 zone=0
Nov 30 13:49:17 kernel: tuple ffffffc0244113c8: 6 192.168.50.21:59667 -> 40.99.10.50:443
Nov 30 13:49:17 kernel: tuple ffffffc024411400: 6 40.99.10.50:443 -> 10.14.0.2:59667
Nov 30 13:49:17 kernel: STATUS[ IPS_CONFIRMED_BIT IPS_SRC_NAT_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
Nov 30 13:49:17 kernel: blog_link:overwriting ct_p=ffffffc0240bde20, new_ct=ffffffc0244e7970 idx=0
Nov 30 13:49:17 kernel: help<0x (null)> helper<NONE> status=8000018e refcnt=2 zone=0
Nov 30 13:49:17 kernel: NFCT: ct<0xffffffc0244e7970>, master<0x (null)>
Nov 30 13:49:17 kernel: F_NAT<ffffffc026ef29f8> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:17 kernel: tuple ffffffc0244e7a08: 17 192.168.50.22:55366 -> 17.248.164.197:443
Nov 30 13:49:17 kernel: tuple ffffffc0244e7a40: 17 17.248.164.197:443 -> 10.14.0.2:55366
Nov 30 13:49:27 kernel: blog_link: 179 callbacks suppressed
Nov 30 13:49:27 kernel: blog_link:overwriting ct_p=ffffffc0240bde20, new_ct=ffffffc0245931a0 idx=0
Nov 30 13:49:27 kernel: NFCT: ct<0xffffffc0240bde20>, master<0x (null)>
Nov 30 13:49:27 kernel: F_NAT<ffffffc02ce1f3f8> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:27 kernel: help<0x (null)> helper<NONE> status=8000018e refcnt=2 zone=0
Nov 30 13:49:27 kernel: tuple ffffffc0240bdeb8: 17 100.64.21.243:50510 -> 89.37.173.43:51820
Nov 30 13:49:27 kernel: tuple ffffffc0240bdef0: 17 89.37.173.43:51820 -> 100.64.21.243:50510
Nov 30 13:49:27 kernel: STATUS[ IPS_SEEN_REPLY_BIT IPS_ASSURED_BIT IPS_CONFIRMED_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
Nov 30 13:49:27 kernel: NFCT: ct<0xffffffc0245931a0>, master<0x (null)>
Nov 30 13:49:27 kernel: F_NAT<ffffffc0287b3bf8> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:27 kernel: help<0x (null)> helper<NONE> status=80000198 refcnt=2 zone=0
Nov 30 13:49:27 kernel: tuple ffffffc024593238: 6 192.168.50.190:58138 -> 17.248.164.108:443
Nov 30 13:49:27 kernel: tuple ffffffc024593270: 6 17.248.164.108:443 -> 10.14.0.2:58138
Nov 30 13:49:27 kernel: STATUS[ IPS_CONFIRMED_BIT IPS_SRC_NAT_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
Nov 30 13:49:27 kernel: blog_link:overwriting ct_p=ffffffc0240bde20, new_ct=ffffffc024411650 idx=0
Nov 30 13:49:27 kernel: help<0x (null)> helper<NONE> status=8000018e refcnt=4 zone=0
Nov 30 13:49:27 kernel: NFCT: ct<0xffffffc024411650>, master<0x (null)>
Nov 30 13:49:27 kernel: F_NAT<ffffffc0279388f8> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:27 kernel: help<0x (null)> helper<NONE> status=8000019e refcnt=2 zone=0
Nov 30 13:49:27 kernel: tuple ffffffc0244116e8: 6 192.168.50.21:59673 -> 40.99.10.50:443
Nov 30 13:49:27 kernel: tuple ffffffc024411720: 6 40.99.10.50:443 -> 10.14.0.2:59673
Nov 30 13:49:27 kernel: STATUS[ IPS_SEEN_REPLY_BIT IPS_ASSURED_BIT IPS_CONFIRMED_BIT IPS_SRC_NAT_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
Nov 30 13:49:27 kernel: blog_link:overwriting ct_p=ffffffc0240bde20, new_ct=ffffffc0244e74c0 idx=0
Nov 30 13:49:27 kernel: help<0x (null)> helper<NONE> status=8000018e refcnt=7 zone=0
Nov 30 13:49:27 kernel: NFCT: ct<0xffffffc0244e74c0>, master<0x (null)>
Nov 30 13:49:27 kernel: F_NAT<ffffffc0287b3378> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:27 kernel: tuple ffffffc0244e7558: 6 192.168.50.190:58137 -> 40.99.150.34:443
Nov 30 13:49:27 kernel: tuple ffffffc0244e7590: 6 40.99.150.34:443 -> 10.14.0.2:58137
Nov 30 13:49:37 kernel: blog_link: 440 callbacks suppressed
Nov 30 13:49:37 kernel: blog_link:overwriting ct_p=ffffffc0240bde20, new_ct=ffffffc0252fd7e0 idx=0
Nov 30 13:49:37 kernel: NFCT: ct<0xffffffc0240bde20>, master<0x (null)>
Nov 30 13:49:37 kernel: F_NAT<ffffffc02ce1f3f8> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:37 kernel: help<0x (null)> helper<NONE> status=8000018e refcnt=3 zone=0
Nov 30 13:49:37 kernel: tuple ffffffc0240bdeb8: 17 100.64.21.243:50510 -> 89.37.173.43:51820
Nov 30 13:49:37 kernel: tuple ffffffc0240bdef0: 17 89.37.173.43:51820 -> 100.64.21.243:50510
Nov 30 13:49:37 kernel: STATUS[ IPS_SEEN_REPLY_BIT IPS_ASSURED_BIT IPS_CONFIRMED_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
Nov 30 13:49:37 kernel: NFCT: ct<0xffffffc0252fd7e0>, master<0x (null)>
Nov 30 13:49:37 kernel: F_NAT<ffffffc0284fbb78> keys[0x00000000 0x00000000] dir<DIR_ORIG>
Nov 30 13:49:37 kernel: help<0x (null)> helper<NONE> status=8000019e refcnt=2 zone=0
Nov 30 13:49:37 kernel: tuple ffffffc0252fd878: 6 192.168.50.190:58152 -> 92.123.180.154:443
Nov 30 13:49:37 kernel: tuple ffffffc0252fd8b0: 6 92.123.180.154:443 -> 10.14.0.2:58152
Nov 30 13:49:37 kernel: STATUS[ IPS_SEEN_REPLY_BIT IPS_ASSURED_BIT IPS_CONFIRMED_BIT IPS_SRC_NAT_BIT IPS_SRC_NAT_DONE_BIT IPS_DST_NAT_DONE_BIT IPS_BLOG_BIT ]
