Following a problem displaying some router setting pages, possibly related to an NVRAM running close to its limit , listed at:
http://www.snbforums.com/threads/problems-displaying-some-webui-settings-pages.24209/
I had a look at moving the NVRAM to the jffs partition but found the wiki guide to be not the step-by-step, how-to guide that I would need. Consequently, I decided to slim down my NVRAM by removing one of the 2 OpenVPN servers I was running. When manually resetting the various pages in the router GUI, I watched how NVRAM was filling up - stats below for interest's sake.
Beforehand, I was running .53, with ssh and 2 OpenVPN servers. NVRAM at 59805 bytes =89%
There may have been an easier way to do this, but I carried out a factory default restore from the Admin page and then powered the router off, waited a minute and then powered on. Here are the stats (NVRAM in bytes). Percentages are of total NVRAM (66536 bytes)
Factory Default Restore
After wireless encryption and new router login credentials set 40416 61%
After 10 manual LAN IPs assigned 41197 62%
After one OpenVPN server set up username/password auth only 48077 72%
After ssh set up 52032 78%
After guest wireless network setup (AES) 52328 79%
(Doing the sums on the space one OpenVPN server takes up, and adding it to the total, if I had continued and set up the second OpenVPN server , it would have brought the total up to 59k or 88%, which is just about where I was before the factory restore, so I'm happy the maths is consistent.)
