peterman25
I have an RT-N66W running the 378.55 Merlin firmware. I get these reports from my wife that is working at home that our internet connection is crap. I take a gander at the logs and see a TON of what is below. Help? What does it mean? I can upload a text file if necessary with about a thousand lines of this stuff. Thanks.
Dec 10 0:00:00 kernel: DROP <4>DROP IN=eth0 OUT= MAC= <1>SRC=xx.xx.xxx.xxx DST=255.255.255.255 <1>LEN=540 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP <1>SPT=9999 DPT=9999 LEN=520
Dec 10 0:00:02 kernel: DROP <4>DROP IN=eth0 OUT= MAC= <1>SRC=xx.xx.xxx.xxx DST=255.255.255.255 <1>LEN=540 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP <1>SPT=9999 DPT=9999 LEN=520
Dec 10 0:00:03 kernel: DROP <4>DROP IN=eth0 OUT= MAC= <1>SRC=xx.xx.xxx.xxx DST=255.255.255.255 <1>LEN=540 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP <1>SPT=9999 DPT=9999 LEN=520
Dec 10 0:00:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=35975 OPT (94040000) PROTO=2
Dec 10 0:01:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=45990 OPT (94040000) PROTO=2
Dec 10 0:02:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=58729 OPT (94040000) PROTO=2
Dec 10 0:03:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=62730 OPT (94040000) PROTO=2
Dec 10 0:04:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=65099 OPT (94040000) PROTO=2
Dec 10 0:05:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=4379 OPT (94040000) PROTO=2
Dec 10 0:07:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=12138 OPT (94040000) PROTO=2
Dec 10 0:07:28 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=185.94.111.1 DST=xx.xx.xxx.xxx <1>LEN=60 TOS=0x00 PREC=0x00 TTL=239 ID=54321 PROTO=UDP <1>SPT=59797 DPT=53 LEN=40
Dec 10 0:08:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=15736 OPT (94040000) PROTO=2
Dec 10 0:10:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=24596 OPT (94040000) PROTO=2
Dec 10 0:10:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=169.54.233.121 DST=xx.xx.xxx.xxx <1>LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=36408 PROTO=TCP <1>SPT=47757 DPT=2121 SEQ=3612824248 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Dec 10 0:11:01 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=209.179.113.233 DST=xx.xx.xxx.xxx <1>LEN=142 TOS=0x00 PREC=0x00 TTL=244 ID=40832 DF PROTO=UDP <1>SPT=53 DPT=23441 LEN=122
Dec 10 0:11:08 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=36423 OPT (94040000) PROTO=2
Dec 10 0:11:28 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=14.182.8.165 DST=xx.xx.xxx.xxx <1>LEN=45 TOS=0x00 PREC=0x00 TTL=50 ID=56742 DF PROTO=UDP <1>SPT=32782 DPT=53413 LEN=25
Dec 10 0:11:28 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=14.182.8.165 DST=xx.xx.xxx.xxx <1>LEN=236 TOS=0x00 PREC=0x00 TTL=50 ID=56743 DF PROTO=UDP <1>SPT=32782 DPT=53413 LEN=216
Dec 10 0:12:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=48110 OPT (94040000) PROTO=2
Dec 10 0:13:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=58956 OPT (94040000) PROTO=2
Dec 10 0:13:16 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=89.248.167.155 DST=xx.xx.xxx.xxx <1>LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=13055 PROTO=TCP <1>SPT=48742 DPT=3389 SEQ=1700326155 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Dec 10 0:14:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=4326 OPT (94040000) PROTO=2
Dec 10 0:14:37 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=46.228.207.18 DST=xx.xx.xxx.xxx <1>LEN=40 TOS=0x08 PREC=0x20 TTL=239 ID=54421 PROTO=TCP <1>SPT=49348 DPT=5957 SEQ=3502053145 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Dec 10 0:15:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=18930 OPT (94040000) PROTO=2
Dec 10 0:16:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=34530 OPT (94040000) PROTO=2
Dec 10 0:16:41 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=119.165.128.104 DST=xx.xx.xxx.xxx <1>LEN=60 TOS=0x00 PREC=0x00 TTL=51 ID=45897 DF PROTO=TCP <1>SPT=42613 DPT=23 SEQ=261320921 9 ACK= 0 WINDOW=584 0 RES=0x0 0 SY N URGP=0 OPT (020405A00402080A0B73DBCA0000000001030304)
Dec 10 0:16:44 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=119.165.128.104 DST=xx.xx.xxx.xxx <1>LEN=60 TOS=0x00 PREC=0x00 TTL=51 ID=45898 DF PROTO=TCP <1>SPT=42613 DPT=23 SEQ=261320921 9 ACK= 0 WINDOW=584 0 RES=0x0 0 SY N URGP=0 OPT (020405B40402080A0B73DCF60000000001030304)
Dec 10 0:16:50 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=119.165.128.104 DST=xx.xx.xxx.xxx <1>LEN=60 TOS=0x00 PREC=0x00 TTL=51 ID=45899 DF PROTO=TCP <1>SPT=42613 DPT=23 SEQ=261320921 9 ACK= 0 WINDOW=584 0 RES=0x0 0 SY N URGP=0 OPT (020405B40402080A0B73DF4E0000000001030304)
Dec 10 0:17:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=37867 OPT (94040000) PROTO=2
Dec 10 0:18:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=41176 OPT (94040000) PROTO=2
Dec 10 0:19:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=44229 OPT (94040000) PROTO=2
Dec 10 0:20:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=49285 OPT (94040000) PROTO=2
Dec 10 0:21:45 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=195.251.255.69 DST=xx.xx.xxx.xxx <1>LEN=32 TOS=0x00 PREC=0x00 TTL=50 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=22901 SEQ=4826
Dec 10 0:22:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=61905 OPT (94040000) PROTO=2
Dec 10 0:22:11 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=58.231.127.89 DST=xx.xx.xxx.xxx <1>LEN=29 TOS=0x00 PREC=0x00 TTL=53 ID=18421 DF PROTO=UDP <1>SPT=44169 DPT=53413 LEN=9
Dec 10 0:22:15 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=58.231.127.89 DST=xx.xx.xxx.xxx <1>LEN=29 TOS=0x00 PREC=0x00 TTL=53 ID=18422 DF PROTO=UDP <1>SPT=44169 DPT=53413 LEN=9
Dec 10 0:23:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=121 OPT (94040000) PROTO=2
Dec 10 0:23:40 dnsmasq #NAME? [273]: DH CPREQUES T(br0 x
Dec 10 0:23:40 dnsmasq #NAME? [273]: DH CPACK(br 0) 10 x
Dec 10 0:24:07 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=10.144.56.1 DST=224.0.0.1 <1>LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=3157 OPT (94040000) PROTO=2
Dec 10 0:24:32 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=92.253.1.244 DST=xx.xx.xxx.xxx <1>LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=23980 DF PROTO=TCP <1>SPT=4638 DPT=23 SEQ=2561909330 AC K=0 WI NDOW=5840 RE S=0x00 SY N UR GP=0 OPT (020405AC0402080A0126FFFE0000000001030304)
Dec 10 0:24:35 kernel: DROP <4>DROP IN=eth0 OUT= MAC=x.x.x.x.x.x.x.x.x.x.x.x.x.x <1>SRC=92.253.1.244 DST=xx.xx.xxx.xxx <1>LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=23982 DF PROTO=TCP <1>SPT=4638 DPT=23 SEQ=2561909330 AC K=0 WI NDOW=5840 RE S=0x00 SY N UR GP=0 OPT (020405AC0402080A0127012A0000000001030304)
