What is the right nvarm syntax ?
octopus
Part of the Furniture
What is the right syntax to get router_name and wan_domain
router="`nvram get router_name`"
wandom="`nvram get wan_domain`"
In a terminal enter
nvram show
Yes of course, brain fart.............. didn't find what i was looking for.
Clearly being able to issue
nvram show >nvram.txt
then opening the resulting .txt file in a suitable editor to perform a search seems beyond your skill level? ;)
However I use the following in my scripts to differentiate between my AC56 / N66
HARDWARE_MODEL=$(nvram get productid)
MYROUTER=$(nvram get computer_name)
but YMMV.
Regards,
Personally I favor this:
nvram show | sort > nvram.txt
Makes it much easier to track down anything.
Thank you Rmerlin and Martineau for your help.
octopus
One more question:
I use: cpu="`cat /proc/dmu/temperature`"
then I get: CPU temperature : 78▒C -- that is ø
but i want to mask that after 78 and keep C
octopus
try
cpu="`cat /proc/dmu/temperature` | sed 's/ø//'"
or
cpu='`cat /proc/dmu/temperature` | sed 's/▒//'"
try
or
first return:
CPU temperature : 77øC | sed 's/ø//'
second return:
failed with return code 2 and error message
./sendmail.sh: line 28: syntax error: unterminated quoted string.
octopus
My mistake.
cpu="`cat /proc/dmu/temperature | sed 's/ø//'`"
or
cpu='`cat /proc/dmu/temperature | sed 's/▒//'`"
My mistake.
or
Thank you, first one working.
octopus
