What say this error message
vaszago
attachment.php
an idea?
What kind of external drive do you have connected to your router? If i had to guess i would say that it is somehow going into power saving mode?
I think you are getting confused with the old IDE /dev/hda etc. naming convention with the disk naming?
This is basically QOS bandwidth sharing using the traffic class htb see
http://luxik.cdi.cz/~devik/qos/htb/manual/userg.htm
or issue
admin@RT-AC56U:/tmp/home/root# tc qdisc add htb help
What is "help"?
Usage: ... qdisc add ... htb [default N] [r2q N]
 default  minor id of class to which unclassified packets are sent {0}
 r2q      DRR quantums are computed as rate in Bps/r2q {10}
 debug    string of 16 numbers each 0-3 {0}
... class add ... htb rate R1 [burst B1] [mpu B] [overhead O]
                      [prio P] [slot S] [pslot PS]
                      [ceil R2] [cburst B2] [mtu MTU] [quantum Q]
 rate     rate allocated to this class (class can still borrow)
 burst    max bytes burst which can be accumulated during idle period {computed}
 mpu      minimum packet size used in rate computations
 overhead per-packet size overhead used in rate computations
 linklay  adapting to a linklayer e.g. atm
 ceil     definite upper class rate (no borrows) {rate}
 cburst   burst but for ceil {computed}
 mtu      max packet size we create rate map for {1600}
 prio     priority of leaf; lower are served first {0}
 quantum  how much bytes to serve from leaf at once {use r2q}
TC HTB version 3.3
However, I don't know what the message means, nor indeed if it is a cause for concern for that model of router.
I have not connected a hard drive. The only thing is connected.
USB stick for internet (Huawei E398)
LAN 2 NAS Qnap connect
LAN 3 NAS Synology connect
LAN 4 PC connect
