What to buy
Ac3200user
Hi all,
I looking for some advice.
My whole house is set up with Asus routers in a Aimesh-setup.
But my main router (RT AC88U) is giving me more and more trouble. It keeps losing its wan-connection to my cable modem, some ethernet-ports randomly stop working, etc etc.
All problems are common, i read here I'm not the only one who encounters them.
I'm at the point of throwing it out of the window, but then I'd have to buy a whole new setup. And with 4 perfectly working RT AC68U-aimesh routers, I guess I'd better buy one new main router.
Preferably an Asus again, as I know the system very well now.
What type would you advice me? I'm looking for a real workhorse, because in a couple of weeks I'm on gigabit fiber. And i have approximately 40 devices connected.
Thanks for your help!
You may find that a cheap 5 or 8 Port switch may solve your RT-AC88U's wonkiness. For $25 or so, it may be worth a try. I'm assuming you know to not use ports 5-8 on your main router, right now.
If the router really is gone, the following links may be helpful. Along with that additional 8 port switch if you need it for your wired clients.
Current Order of Recommended Routers Late 2021
Depending on your region, the RT-AX86U is the best bang for the buck. The RT-AX68U is the affordable entry-level current router today.
