What's the most current firmware for ET12
mlai
Hello gurus!
I am experiencing upload throughput issues and reached out to ASUS and then realized that my ET12 came with firmware 3.0.0.4.386_48826 that is even newer than on their website
3.0.0.4.386_48823.
Is the 48823 most current stable for the ET12? Should I manually downgrade from the current firmware on my ET12 back to 48823?
The most stable firmware is the one that is most stable for you.
You need to try it on your network environment.
If it does not work, then a different path is called for.
Ill be trying the original, because of connection issues to the 6ghz ssid, version 47636.
So it's exactly like mentioned, whatever works for you with new stuff.
This router will be getting 388 code firmware for sure, but when it's ready. My guess is soon.
