What's the trick to dnsmasq.conf.add with manual assignments?
jrhjr
Is there a trick to using dnsmasq.conf.add? All I'm doing is putting dhcp-host lines into it...
I've tried :
chmod a+rx /jffs/configs/dnsmasq.conf.add
nvram set jffs2_scripts=1
  • Even though this was already set in the web gui
The lines I'd like get added to : /tmp/etc/dnsmasq.conf but the manually assigned addresses don't show up in the web gui? I assume the should? I've tried a variety of formats including the prescribed format from this forum:
dhcp-host=00:15:5d:01:20:0e,host1.domain.com,192.168.1.242
And the way I noticed the router putting them in:
dhcp-host=E8:AB:FA:6A:2E:5A,set:E8:AB:FA:6A:2E:5A,192.168.1.213
I haven't confirmed whether the clients still pull the addresses but I sort of expect they won't?
This is running Asuswrt-Merlin 386.2 on an RT-AC86U that is currently meshed with an AC68U and an XT8.
Help?
Thanks for the response - I did not know this existed and am coming up on the internal limit so it'll be useful.
While I have your attention - are you aware of any solutions to reserve/manually assign addresses on a AiMesh guest network sync'd to all nodes (so that dnsmasq/dhcp will distribute them vs. hard coding the device itself)? Will YazFi do this (though I'm not sure of the YazFi status on the 386.* firmware - last I read you were working on it and it was complexicated)?
