At our house we have 2 internet connections, we've setup the 2nd one as a backup after hearing from a friend of ours that did the same.
The reason that more homes, small offices and companies are ever more often getting a 2nd internet connection is that internet is ever more a part of our lives.
More and more in our society have come to depend on the internet, so it's only natural that we seek assurances that it will be always available. It's a matter of availability.
For others it's a matter of speed. Turns outs combining 2 or more connections is the easiest way to get a faster connection instead of waiting for years until your provider decides to upgrade it's network.
But we stumble on our routers limitations. I have.
I'm currently using an Asus RT-N16, it's great machine, it's stable and it's powerful.
But it can't do dual-wan, or barely can with the help of this also great firmware and mod wrt-merlin.
I have got it to do dual-wan, but it's limited to the "fail-over" mode. Meaning that you can get higher availability by adding a 2nd connection.
But the "load-balance" mode doesn't work, so you can't combine the 2 connections to get more performance.
When I set it up as load-balance I got the same behavior as on fail-over. That is only 1 wan would be used at a time.
But even the fail-over mode isn't perfect. Ideally I'd like the router to detect a failing wan and switch to a healthy one more quickly, currently it takes a while and you might get a few failed connections before the internet is reestablished.
I'd also like it to keep an eye on the first connection and when it's back up, immediately switch back to it. That's currently not possible, the router do the switch and never look back. Perhaps it will return back if the 2nd connection fails, but I haven't tested that.
I have also found another firmware that works on my Asus RT-N16 and does dual wan with good feedback on the forums, that's Tomato DualWan (dualwan.cn).
Here the problem is different. The source code has been kept close and there are reports that it contains malware that could compromise your privacy and security, for example silently collecting your passwords and submitting it to someone in China. Or worse, such as DNS hijacking of your bank's website.
This defeats the whole point. If we can't get safe and realiable internet, then a router's firmware is useless.
So I'm still looking for a way to get good and cost effective dual wan for my home network.
I've heard DrayTek has good routers for that, anybody tried?
If you have more info on dua wan or (multiple wan) please share, I'm eager to learn and to get a solution for this.
