Where can I see what port forwarding is active?
Nerre
I thought I would see it by running "iptables -L", but it seems to only contain uPnP forwarded ports and not the ones I have explicitly forwarded?
I was looking into it for debugging purposes.
it's in the nat table
 iptables -t nat -L -n -v
Also, the System Log -> Port Forwarding will show all forwarded ports, including UPNP ones. In recent versions of my FW I also identified these so you can tell which are from UPNP.
Ah, I didn't realise there were different tables and not stating a table defaulted to "filter"...
