Which aimesh router will strengthen the 2.4 GHz network?
sisimon
Hello. I previously had a tp-link mesh network Deco M4 (5 pieces). However, there was a problem with wifi calling with Samsung phones. It was very good with other phones. I have now bought Asus RT-AX82U and node RT-AX59U. I have a good range in 5GHz. However, I would like to buy a router to strengthen the 2.4GHz signal because the Huawei P30 Pro phone uses it for wifi calling. When the phone connects to the 5GHz network, wifi calling disappears. I created a network for guests only 2.4 GHz and the phone works perfectly on it. However, I would like to strengthen this frequency. What router should I buy for the node? What model would be best for 2.4GHz?
I don't know English, google translate
The sister forum to this one, https://www.smallnetbuilder.com/, has the choices to rank routers by range, by speed, or by overall performance. Choose the parameters most important to you and search accordingly.
If you are using AiMesh, best practice is to have all nodes, including the main router, the same hardware and same firmware. Anything other than that is an experiment and may or may not work.
Use wired (ethernet) backhaul if possible.
