Which ap ?
Wolfen
I have a ASUS rog ax11000 As my main router. I want to set up an ap in my basement. I have 2 choices for the ap. I have a NETGEAR rax120 and a ASUS rt68u. I think rax120 is probably the better router but should I stick with all ASUS? Would there be any conflicts using the 2 different brands or any advantage to sticking with all ASUS? I have decided against the aimesh because I do not wish to lose my 2nd 5 ghz band on the ax11000. Thanks for your help.
If not in AiMesh, then the RAX120 should be the better choice. :)
But even better, you have both, test and let us know too which wins in your network environment. :)
