which Asus model for WG 800+ Mbps speed?
dvan56
Hello
Have 1 Gbps ISP speed, need 800+ WG speed
1- It there any non wifi7 ASUS model than can give me 800+ Mbps WG speed ?
2- I know ASUS ROG GTAX6000 can give 650 Mbps, doing research seems this model for some unknown reasons have bad WG performance.
3- Heard from this video:
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
(12:15) that TUFAX6000 can give 1000 Mbps WG speed? is this right ?
4- Currently have RTAX82U which is giving me around 360 Mbps GB speed.
Which model do you guys recommend?
thanks in advance
You're dreaming, right?
No. For that kind of throughput you will need an x86-based router.
How about a "cheap" wifi7 router like the RT-BE88U which have 2.6 quad processor ?
I tested the GT-BE98_PRO last week (same CPU), and the highest I got running Speedtest through a WG tunnel with my VPS (which normally saturates my Gbps FTTH when moving files over SSH) was around 320 Mbps. The bottleneck is not the VPN itself, it's the fact that the WireGuard protocol is not compatible with Broadcom's NAT acceleration.
Mediatek Filogic 830 can hit 900 consistently over Wireguard...
That's a GL-Inet MT6000 router that can run OpenWRT out of the box with all the bells/whistles...
Actually not - I was a bit surprised myself on WG throughput on a MediaTek based device... 800 is not uncommon for this chipset...
Filogic 830 is a bit of a game changer - not just for performance, but they're beating up both QCA and Broadcom on price...
