Hi there!
I live in a house with two floors, and very thin drywalls. There is absolutely no need for a mesh system - a single router works perfectly fine.
I have been using the Asus rt-ac68u with the latest merlin firmware and I am absolutely loving it. This is all I need from a router.
I would, however, like just a little bit better range. I have no interest in Wifi 6 or 7, and there is a lot of routers for Wifi 5 now on the second hand market - for really good prices. I'm thinking this is a good opportunity to upgrade my gear.
What is important to me?
- Merlin firmware compatibility
- Range
- Stability
- Power consumption (there are some models that use a little bit to much in my opinion)
Which of all the Asus routers would you recommend based on the above (price is not relevant)?
Thank you!
- Range
- Stability
Thank you!
