Which of these Merlin versions do you recommend, last beta2 or latest stable 39.0-em?
  • Latest RT-N66U_3.0.0.4_374.40_beta2
    Votes: 4 57.1%
  • Latest STABLE RT-N66U_3.0.0.4_374.39_0-em
    Votes: 3 42.9%
  • Total voters
    7
darkknight74
Which of these Merlin versions do you recommend right now, last beta2 or latest stable 39.0-em?
It depends on your environment. If you are just tinkering around at home, use the beta. If you have devices or services on your network that are mission critical, stay with 39_0 EM.
Starting a poll about a beta which will be most likely replaced by a final release in the coming days isn't a good idea.
I'm waiting for 374.40 final before I upgrade from 374.39_0-em.
Does this mean your closer to finding a fix for the reboot issue ? If not i will stick with 40 alpha4.
No, it means that I've given up.
You should test each firmware to see what is best for your setup. I mean it's really easy to switch between firmwares..
