Which Router supports wireguard, kill-switch, auto-reconnect etc?
alphaswe
Hello people!
Which router would you recommend to use as a stable VPN client running 24/7?
I would like the router to support:
1. WireGuard client that can connect to, for example, OVPN.com with a dedicated Swedish IP.
2. Kill-Switch (if the VPN goes down, you should not be able to access the internet).
3. Auto-Reconnect (if the VPN goes down, it should automatically try to reconnect to the VPN server until it’s back online).
4. Not required: Whitelist domain names (For routing certain domains outside the VPN tunnel).
I am a newbie, so prefer to have it very very easy to install.
Thanks for your help! ;)
