mobiledynamics
I have both tried a couple of 3700's setup in a WDS fashion. Using OEM firmware...
The baked in WDS setup for the 3700 was terrible. The AP's would connect and then disconnect from the main AP.
With that said, I may flash one of the 3700's with DDWRT as a client bridge.
I do need to order 2 more dual band N units to use as bridges too. Which ones would you guys recommend for throughput and performance - to be used in client AP bridges with stock OEM firmware of flashed to DDWRT firmware to be used as client access bridges
