Tom Brough
If so which method are you using?
Kamoj add-on or HelloWorld method? What's the pros and cons of each??
Cheers
Cheers
aegis is availableI've been using HELLO_wORLD's blocking method since it was first available.
I'm using it with the default firehol lists to block malware/bad actors.
I've installed the extra util iprange, easy & no issues.
I like the fact it is not over-engineered.
Will try his new named version when available.
Ah so yours is an IP blocking system, and kamoj blocks via dns lists or Manually added ip addresses. (Similar to openwrt adblock and banip)
I like the way yours survives a reboot, having to tinker with the router every reboot does get on my nerves.
I was considering using blacklists (and whitelists) with DNSCrypt, instead I tried NextDNS which was much easier to implement. I created an account on nextdns.io (free), configured a few block lists and then configured it on the Orbi with Stubby. Setup was pretty easy and required copying and pasting the configuration from the NextDNS site and rebooting Orbi.
One advantage of using NextDNS without adblocking is that I can still block trackers and also trackers that mask themselves. the custom lists on NextDNS are a nice feature and requires 0 changes and maintenance on the router.
I looked at NextDNS but it's not free anymore, you get a certain amount of free traffic then it stops working until the next day unless you pay. I also see it's moving to a completely pay only service soon.I was considering using blacklists (and whitelists) with DNSCrypt, instead I tried NextDNS which was much easier to implement. I created an account on nextdns.io (free), configured a few block lists and then configured it on the Orbi with Stubby. Setup was pretty easy and required copying and pasting the configuration from the NextDNS site and rebooting Orbi.
I assume you run Debian via entware with pi-hole installed on it? Does it survive router reboots and firmware upgrades? Can't find much about it on the internet, did you use a guide or did you just do it all yourself.I'm using Aegis (by HELLO_wORLD) mainly for blocking malware.
And I've managed to get Pihole v5 running (compiled via entware and some hacking) on my R7800 for ad blocking.
I like Pihole, because it also comes with a nice GUI and it has the possibilility to blacklist or whitelist DNS names per device.
Yeah a gui even just to show it's working would be nice... What we need is @kamoj to just make an entire new gui for the whole router as the stock Netgear one is the most outdated looking thing I've ever seen.
Thread starter | Title | Forum | Replies | Date |
S | R6330 in bridge mode suddenly refuses to connect via Wi-Fi to the "main router" | NETGEAR AC Wireless (Wi-Fi 5) | 0 |
Welcome To SNBForums
