I really don't understand. First they screwed up dual wan for years and I am not sure if they ever fixed it, I gave up and bought Synology AC2600 for this purpose which works rock solid. PPPoE on AC68U was also hit and miss and as I can see from Synology AC2600 it was definitely not down to my ISP but down to some sh*tty implementation of this protocol by Asus.
In another place I have been using AC86U (before AC56U) and honestly on both the PPPoE works far from how it should work. I had PPPoE before with VLAN and they way it worked especially during connection establishing was flaky at best. Later my other ISP was using Automatic IP assignment, so no PPPoE - at least Automatic setting they got right. Now this other ISP have changed fiber optic modems to support PPPoE and AC86U simply struggles. I got it working 1-2 times at the beginning, when I disable WAN manually and enable, it will never re-connect. At least it WAS connecting via PPPoE upon reboot 2-3 times. After that it doesn't work either, regardless of how many times I reboot or how long will I leave it to negotiate the connection.
I was about to call my ISP, but first I tried 2 things: direct PPPoE on my MacBook Pro - it worked. Then I tried my dusty R9000 and guess what - it just works.
Seriously Asus what the hell. Plenty of users report PPPoE issues on this forum which are not necessarily down to their ISP. Btw, latest 384.10 here. Log says no particular errors and the GUI WAN status is stuck on "renewing"...
