Why does adding AiMesh node via ethernet backhaul require close proximity
Johno
I've just acquired an AX router (AX-92U) to add to my existing AiMesh and whilst it's found by the main router (an AX-86U) in the AiMesh setup, it can't be added as a node because apparently it needs to be 2-3 metres from the root mesh node. I have the AX-92U connected via an ethernet cable from an unmanaged switch. I've found in the past that new nodes need to be close to the root node when adding, even if wired backhaul, but why is this?
May be the version of firmware on the node. Then again, maybe not. Could have something to do with WPS which is active in the node add cycle. Some things are hard to explain but if following the instructions works, just do it. With that said, my mesh node is Ethernet connected directly to the router, router LAN port to node WAN port, and I can remove it and add it back with no issues.
Yes, same here, it's just the inital "add node" process that seems to require close proximity and (hence I'm guessing) the wireless connection.
Not a requirement, especially when wired... especially since it is found. Typically something else is getting in the way. Try a different wire and without the intervening switch.
I am able to add wired and wireless nodes at 77 ft.
OE
