Why might a service not start on start-up?
p_shep
Currently running Merlins fw, version 3.0.0.4.354.28.
Hacked in Optware, which was moved over from use under dd-wrt installed via OTRW2... much script tweaks etc.
Most things are working and starting correctly on boot using the SXXxxxx method. Lightthpd, transmission, few other bits and bobs.
However, I compiled the bitcoin client, and while it works just fine and dandy when initiated manually via the command line, I can't get the thing to work on boot, even at S99 with 120 second delay. The logs show that the script calls the executable, but it just doesn't start.
So the question is, how do I get it to start? Cron job? Some other method?
Cheers.
Here's the bin if anyone wants it :)
https://www.dropbox.com/s/25yl2di54g4kfu1/bitcoind-0.8.2-mipsel.tar.gz?v=0rc-
