System Error Message
Part of the Furniture
Since there has been so much demand for VPN i am going to say that most of the demand is misplaced. Using a VPN for anonymity is no more secure than using a layer 3 network over a layer 2 network. Every packed sent in a layer 2 network containing a layer 3 network would appear like this [(L2 header), (payload containing L3 header and payload)]. A VPN network is layer 4 in the networking OSI model.
Even if you encrypt the payload the packets still travel using layer 3 over the internet so while information cant be read they can be tracked in various ways other than reading the packet source/destination. Take for example on how some sites using TOR can backtrace you since TOR encrypts your traffic over 3 nodes and can be imagined as a VPN with many seperate tunnels but all on the same network. So to use a VPN as a proxy is just as detectable as using layer 3 routing in which it is very easy to determine a host on the network through techniques such as fingerprinting and detecting hosts behind a NAT (there are actual products that do this used by various ISPs, organisations and such).
This is why if you see a VPN provider selling VPN service for the reason of anonymity you should not use it because a VPN is never meant for anonymity, it is only meant to be used to create networks, it is just companies preying over the various confusions and lack of information. A VPN doesnt protect your anonymity, it only routes your traffic through another node and a VPN would definitely keep a log of you because it is required by law just as it is for ISPs (im not sure if they are classified the same way as ISPs but the service is actually the same).
If you want to protect your anonymity use an encrypted proxy instead. Even though a proxy has more processing requirements and less compatibility it can change traffic that you cannot tell if something is behind it and it is well known to defeat NAT detection and detecting hosts behind a NAT. A proxy is detected either by a known proxy host or through the lack or forged information.
Even though a VPN offers compression it doesnt mean a proxy cannot do the same if using a tunnel between the proxy server and the client since you can use VPN between you and the proxy to encrypt and compress data.
I really hope this thread gets stickied to as a MUST READ before deciding to get a VPN service when it is more likely a proxy service that you are looking for.
