I wanted to migrate traffic data from one router to another. Thought, it is on USB stick, it will be a simple task. Wrong!
Removed USB stick from Asus RT-AC56U and plugged it into Asus RT-AC68U. Asus RT-AC68U would not see the stick. Fearing the catastrophy I had with Asus RT-AC56U (bricked due to writing to USB stick), I first did multiple resets. Tried all sticks I had at hand, and found that only one stick would work in Asus RT-AC68U and only in USB3 socket. Others would light up the LED in front of the router (or not even that) but they would not register and could not be used at all.
My attempts to migrate the trafic data itself (tomato_?stats*.gz) taking different names into account were fruitless. Then I looked at the router itself and found traffic.db. So, I replaced it with the same file from the old router. All seems to be well. New router shows all traffic made on the old router.
So, if this trafic data is written to the /jffs/traffic.db and not to RAM (meaning: lost when powered off), why have it saved to USB stick? It is easier to simply backup /jffs/traffic.db and forget about saving it externally.
Or, am I missing something?
