Why was CONFIG_NETFILTER_XT_TARGET_TPROXY Reverted from Asuswrt-Merlin Linux-2.6.36 Kernel?
garycnew
@RMerlin (Eric)
Curious as to why CONFIG_NETFILTER_XT_TARGET_TPROXY was reverted from the Asuswrt-Merlin Linux-2.6.36 kernel, yet retained in other Asuswrt-Merlin kernels?
Respectfully,
Gary
@bsdsource
I attempted to add an iptables rule that uses -m socket, but it fails as though the Asuswrt-Merlin Linux-2.3.36 kernel wasn't compiled with CONFIG_NETFILTER_XT_TARGET_TPROXY support.
Respectfully,
Gary
Did you load the module?
admin@rtac66b1:/lib/modules/2.6.36.4brcmarm/kernel/net# modprobe xt_TPROXY
admin@rtac66b1:/lib/modules/2.6.36.4brcmarm/kernel/net# lsmod | grep TPROXY
xt_TPROXY                958  0
nf_tproxy_core          1262  1 xt_TPROXY,[permanent]
xt_TPROXY                958  0
@RMerlin
That was the problem. The xt_TPROXY and xt_socket kernel modules weren't loaded. I guess that's what I get for assuming that they were loaded by default.
Thank you for bringing the obvious to my attention.
With Great Respect,
Gary
xt_TPROXY                958  0
I just entered the codes above but only got the first line
xt_TPROXY xxx 0
How to fix it?thanks
PS: my router is AC-86U
xt_TPROXY xxx 0
Different kernel. This thread is discussing kernel 2.6.36, your router runs kernel 4.1. That module does not exist on your router.
xt_socket is not the same thing as nf_tproxy_core. The latter no longer even exists in the net/netfilter/ source code of 4.1.xx, there's nonly xt_TPROXY.
@Tech9
Did I misunderstand your response in the previously referenced post suggesting you were able to modprobe xt_socket and xt_tproxy on a kernel-4.1 device?
Respectfully,
Gary
@Tech9
Respectfully,
Gary
admin@RT-AX86U:/# uname -r
4.1.52
admin@RT-AX86U:/# modprobe xt_socket
admin@RT-AX86U:/# modprobe xt_TPROXY
admin@RT-AX86U:/# lsmod | grep xt_
xt_TPROXY               5057  0
xt_socket               3926  0
Not sure. You asked me to check something, I posted the result. It was months ago, I don't remember on AC86U or AX88U.
4.1.52
xt_TPROXY               5057  0
xt_socket               3926  0
@ColinTaylor - Thank you for confirming what @Tech9 previously verified.
@RMerlin - Have I misunderstood your point?
I'm confused by why you're confused. RMerlin's reply was in response to post #7. In that post @bhaji said his output was different from RMerlin's output. He didn't have the nf_tproxy_core 1262 1 xt_TPROXY,[permanent] line. RMerlin explained why the nf_tproxy_core line was missing.
@ColinTaylor
That's what I get for not reading each post carefully.
Thank you for the clarification.
Respectfully,
Gary
