Wi-Fi client sometimes reconnects for no reason
bidenkoanton
Hi guys. I have a problem that I've been troubleshooting for about a month now with no luck, so I finally gave up and decided to post here.
One of the phones (Samsung Galaxy S22) sometimes decides to disconnect and reconnect multiple times to wifi even when in the room near AP. All other phones (even another Galaxy S22 with identical settings) don't exhibit this behavior. The AP is Asus RP-AX58 connected in repeater mode (not AiMesh node) to RT-AX88U Pro over 5GHz, clients over 2.4GHz. All firmware latest, hard reset, then configured with minimal settings.
Here's the log (log_level set to 8):
Mar  9 11:46:25 wpa_supplicant[2652]: eth2: WPA: Group rekeying completed with c8:7f:54:5e:a6:b4 [GTK=CCMP]
Mar  9 11:46:25 kernel: CFG80211-ERROR) wl_cfg80211_set_rekey_data :
Mar  9 11:46:25 kernel: seting gtk_key_info failed code=-23
Mar  9 11:49:14 hostapd: wl0.1: STA 98:b8:bc:a5:73:a0 WPA: group key handshake completed (RSN)
Mar  9 11:49:14 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: group key handshake completed (RSN)
Mar  9 12:22:42 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: disassociated
Mar  9 12:22:42 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Disassociated due to inactivity (4), rssi:-47
Mar  9 12:26:46 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:0
Mar  9 12:26:46 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:0
Mar  9 12:26:46 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-47
Mar  9 12:26:46 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:26:46 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:26:46 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:26:46 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session A8FD3B4EF645298A
Mar  9 12:26:46 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:27:54 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-47
Mar  9 12:27:54 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:27:54 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:27:54 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:27:54 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session A8FD3B4EF645298A
Mar  9 12:27:54 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:28:35 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-47
Mar  9 12:28:35 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:28:35 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:28:35 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:28:35 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session A8FD3B4EF645298A
Mar  9 12:28:35 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:29:21 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-46
Mar  9 12:29:21 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-46
Mar  9 12:29:21 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:29:21 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-46
Mar  9 12:29:21 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session A8FD3B4EF645298A
Mar  9 12:29:21 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:29:50 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:0
Mar  9 12:29:50 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:29:50 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-47
Mar  9 12:29:50 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:29:50 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-47
Mar  9 12:29:50 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session A8FD3B4EF645298A
Mar  9 12:29:50 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:34:24 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:0
Mar  9 12:34:24 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:0
Mar  9 12:34:24 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-49
Mar  9 12:34:24 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-49
Mar  9 12:34:25 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-49
Mar  9 12:34:25 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:34:25 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-49
Mar  9 12:34:25 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-49
Mar  9 12:34:25 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session A8FD3B4EF645298A
Mar  9 12:34:25 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:35:19 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: disassociated
Mar  9 12:35:19 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Disassociated due to inactivity (4), rssi:-48
Mar  9 12:40:00 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:0
Mar  9 12:40:00 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:0
Mar  9 12:40:00 wlceventd: wlceventd_proc_event(685): wl0.1: Auth B4:0B:1D:69:84:AD, status: Successful (0), rssi:-40
Mar  9 12:40:00 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind B4:0B:1D:69:84:AD, status: 0, reason: Unspecified reason (1), rssi:-40
Mar  9 12:40:00 hostapd: wl0.1: STA b4:0b:1d:69:84:ad IEEE 802.11: associated
Mar  9 12:40:00 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc B4:0B:1D:69:84:AD, status: Successful (0), rssi:-40
Mar  9 12:40:00 hostapd: wl0.1: STA b4:0b:1d:69:84:ad RADIUS: starting accounting session CACF6ADCBE3F3DCE
Mar  9 12:40:00 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: pairwise key handshake completed (RSN)
Mar  9 12:46:25 wpa_supplicant[2652]: eth2: WPA: Group rekeying completed with c8:7f:54:5e:a6:b4 [GTK=CCMP]
Mar  9 12:46:25 kernel: CFG80211-ERROR) wl_cfg80211_set_rekey_data :
Mar  9 12:46:25 kernel: seting gtk_key_info failed code=-23
Mar  9 12:49:14 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: group key handshake completed (RSN)
Mar  9 12:49:14 hostapd: wl0.1: STA 98:b8:bc:a5:73:a0 WPA: group key handshake completed (RSN)
Mar  9 13:46:25 wpa_supplicant[2652]: eth2: WPA: Group rekeying completed with c8:7f:54:5e:a6:b4 [GTK=CCMP]
Mar  9 13:46:25 kernel: CFG80211-ERROR) wl_cfg80211_set_rekey_data :
Mar  9 13:46:25 kernel: seting gtk_key_info failed code=-23
Mar  9 13:49:14 hostapd: wl0.1: STA b4:0b:1d:69:84:ad WPA: group key handshake completed (RSN)
Mar  9 13:49:14 hostapd: wl0.1: STA 98:b8:bc:a5:73:a0 WPA: group key handshake completed (RSN)
If the other clients are working fine at the same time and location, then i is likely to be an issue with that specific client. The client determines which AP to connect and when to drop. Could be a hardware issue or low level config issue with that specific unit.
Are you running Radius authentication server ?
Specific client issue. There is nothing much to troubleshoot on the router/extender. You have tried already perhaps, but use 20MHz wide channel only on 2.4GHz band, try different channel, forget the connection on this phone, re-connect again, try the 5GHz band instead.
Thanks for advices. Not Radius server, 20MHz, perfect channel, forgot connection. Looks like I have to do a hard reset on the phone.
