SecurityAmateur
Total noob here. Naive, late tech adopter.
Need to link surveillance cam mounted in unattached garage to Modem about 35 yards away. Wifi originates from conventional modem signal and is NOT 5G. The WiFi signal needs to penetrate wall from front of house to the outdoors and then penetrate garage wall to indoor surveillance cam. Is an access point recommended? And if so, will I run into compatibility issues between access point and modem? Do access points need to be hardwired?
Also - any other trouble-shooting issues I should anticipate?
