nycelitemaster
Hi All,
I am writing to seek assistance. My house is 1100 sqft. Back in 2017, I added 1 RT-AC68A and 2x RT-AC68U. I have attached a floor plan and diagram that explain the whole placement of the routers. For the past 3 years, I ran RT-AC68A IP (192.168.1.1) as a main router/gateway and 2 RT-AC68U (192.168.1.2 and 192.168.2.1) as an AP Repeater. 1st RT-AC68A sits in my bedroom. Few months after I added Ring Bell to the front door which couldn't connect to my RT-AC68A, then I added a 2nd RT-AC68U (Ethernet backhauled w/ AC68A) on the other side of the house. Both devices sit 31 linear ft apart. This fixed my ring issue.Then I finished my basement and added an office. I also created separate SSIDs which allowed me to hook up devices by location (All devices near bedroom connected to AC68A, while all devices near Living, were connected to AC68U in living) and Basement devices were connected to AC68U in Basement
WiFi SSIDs are as follow
AC68A - WLAN and WLAN5G
AC68U - WLANLiving and WLAN5GLiving
AC68U - WLANBsmt and WLAN5GBsmt
This gave me an issue when I moved through one location to the other, wifi drops, and reconnects. To avoid this, I created a mesh network using AiMesh Nodes. I do not care about 3rd router being on a different network anymore. So all are on the same network. But my wifi signals have dropped and heavily fluctuate. New Firmware + AiMesh sort of reduced the 2.4Ghz and 5Ghz range.
I did so much reading in the past few days, and adjusted the settings and reflashed the firmware and reset before and after all devices, and re-created mesh w/ 2 nodes. I used Wi-Fi Analyzer App and the signal coverage is ok w/ 2 Routers, but not excellent. You guys think am I overdoing w/ 3 routers that are causing the issue?
How many devices/nodes should I be using...
Secondly, my ring alarm system sits between Bedroom and Livingroom and constantly goes offline. I believe it is having issues with trying to figure out which to connect to...Any suggestion will be helpful. I am looking to streamline and improve my connectivity.
Note - all devices are running Merlin's latest firmware
