Venom
Hi All,
I am having problems troubleshooting my issue. I live in a very rural area with just about no cell service coverage. Verizon is the only one. I get one bar of signal if I stand in my yard and hold my phone up. Wifi Calling is what I use 100% of the time.
Initially when I installed My Asus Aimesh system it would always drop out between nodes, But after a few Firmware updates it had started to work perfectly for the last couple of years. My Main Router is a RT-AC5300 with Firmware: 3.0.0.4.386_48377-g3e428e2. I have 3 AiMesh Nodes. Two are RP-AC1900 that are Wired with Firmware: 3.0.0.4.386_51255-g486ded6. The third is a RT-AC68U connected Wirelessly with Firmware: 3.0.0.4.386_51255-g486ded6.
I used to be able to walk from My house to my workshop and vice versa without dropping a Wifi call as well as work around my yard. One of the RP-AC-1900 units is in the Workshop. Here is my troubleshooting problem. The Main Router and the AiMesh Nodes all updated to the latest software on the same day My Google Pixel 7 Pro got an update. Within a day I started experiencing drop outs on Wifi Calls when switching between nodes. I went through the settings on my cell phone and it appears they added a new setting to Wifi Calls. Before you had one option to use Wifi Calling if a Verizon signal was not available. Now you have two settings one that makes the cell signal a priority and one that makes the Wifi signal a priority. Using either setting I have the drop outs between nodes. To further make things difficult they have upgraded to Verizon 5G. Now I get one bar of cell signal randomly as I walk around without lifting the phone up into the air. I am using the Wifi Priority setting on the Phone. According to what I have read The Wifi Priority setting will always pick Wifi over the Cell Sgnal. As I walk to my house from the workshop looking at the phone I see when the Wifi Signal stops and it then tries to connect to the cell signal which is not there. Then the phone says no Mobile Signal available call lost. Then it takes the phone a minute to regain a Wifi Signal from the Houses RT-AC5300.
What is the best way to troubleshoot whether my problem is the AiMesh setup or the Cell Phone.
Any help would be appreciated.
Thanks,
Chris
Thanks,
Chris
