sodaorseven
Hello,
I have been having an issue I can't seem to fix. The wifi on my Macbook Pro keeps cutting out, about once every 10-20 minutes. Turning the wifi off and back on temporarily fixes the problem. My router is an ASUS RT-AX3000.
Here is a list of things I have tried so far:
I looked into the logs, but am not really sure what I am looking at. And to make matters worse the applecare on this machine just expired.
Also worth noting that the network has been, and continues to work fine for all other devices (another macbook pro, two iphones, smart tv, etc.) and nothing major changed with the network before this occurred.
As of right now, the router was recently factory reset. The only thing I changed was SSID and passwords.
At this point, does this most likely seem like a router or a computer issue? Any tips on what to try next?
Thanks!
- Restart computer
- Turn wifi on/off
- Remove network and reconnect
- Remove wifi service and reestablish (on my mac)
- Rebout router
- Factory restore of router
- New SSID, new channels, new wifi password
- Reset the PRAM & SMC (on my mac)
- Updated the Mac OS to Big Sur (from Catalina)
- Ran Wireless Diagnostics (on my mac)
Your Mac experienced an unexpected Wi-Fi connection drop, which can be caused by a combination of environment, configuration, and software problems.
Provide the diagnostics report created in /var/tmp to an AppleCare customer support representative for further analysis.
Thanks!
