i have this problem for a long time now, both with official and merlin firmware
setup
RT-AX88U router
RT-AC86U AImesh node
all latest merlin
smartconnect on
1 single SSID for both 2.4 and 5ghz
system can work for days stable without disconnects then all of a sudden(after 3 days)
when coming home my iphone XS/15pro connects to the main router wifi and then the complete wifi network gets unstable and devices disconnect/reconnect al the time
it is like something is jamming the wifi and all the devices try to reconnect.
the trigger is always the same.
somebody is coming home and then the problems start.
only way to solve it is to reboot router and aimesh node.
and first i suspected 3 ESPeasy modules but i am not so sure these are the cause since everything works untill somebody comes home and logs onto the wifi network
PMF is switched off
nothing is showing in the log(notice level)
any help would be appreciated
setup
RT-AX88U router
all latest merlin
smartconnect on
PMF is switched off
