geolykos
Hi, new here. I have an Asus RT-AC86U for over a year now and I've had all sorts of issues related to its wifi.
Firstly, I believe it's a great router with great speeds and wifi range.
Aside from that, I've had several issues with the wifi:
1) It drops most clients when over 20 devices are connected over wifi. The only way to fix it is to hard reset the router (not via GUI). The number is a ballpark figure but it seems to happen a lot when we have guests or family over and more devices connect. Normal amount of wifi devices is around 15.
I added a switch where I connect all the wired devices to get some routing pressure of the router. This seemed to help a bit but issue still happens occasionally. Any ideas if 20+ devices over wifi would normally cause an issue? Using dual band smart connect feature.
2) Recently it started dropping all devices from the Guest 2.4ghz network. The only to fix this one is to disable and re-enable the Guest network. I have all my cameras and peripherals on the Guest 2.4ghz network for security reasons. Using 2.4ghz as some of them don't support 5ghz.
I only have 5 devices on the Guest network and I'm up to date with the Asus firmware version (3.0.0.4.386_40451). Router currently has 21 clients connects 7 of which are wired. I'm not sure what the issue could be. Is this a router resource thing or a problematic router?
3) I also had a major issue recently (only happened once) where it lost of all configuration settings (except for wifi networks) and I had to configure all port forwarding etc. Restoring the config backup I had broke the firmware and I had to factory reset. Raised it with Asus support and they told me to factory reset...
Would upgrading to AX86U help resolve any of the above issues? Is this just a problematic router or are these issues common with Asus routers?
