WIFI keeps disconnecting my 2.4Ghz devices
father_web3
Can anyone help me I have AX300 V2, and its been a few weeks I've been having this problem, and cant figure out why I'm getting this; I have main wifi with dual-band and one guest network for my smart devices with 2.4ghz and one or twice a day all devices on guest networks starts disconnecting and reconnecting without connecting I already tried to change few things in the router like beam formatting, airtime fairness and few other settings but that did not helped me if anyone know how I can fix it please help me :D here's my log
Aug 13 18:41:54 wlceventd: wlceventd_proc_event(685): eth6: Auth 94:18:65:5B:B6:FE, status: Successful (0), rssi:0
Aug 13 18:41:54 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 94:18:65:5B:B6:FE, status: 0, reason: Previous authentication no longer valid (2), rssi:0
Aug 13 18:41:54 wlceventd: wlceventd_proc_event(645): eth6: Deauth_ind 94:18:65:5B:B6:FE, status: 0, reason: Unspecified reason (1), rssi:0
Aug 13 18:41:54 wlceventd: wlceventd_proc_event(722): eth6: Assoc 94:18:65:5B:B6:FE, status: Successful (0), rssi:-51
Aug 13 18:41:55 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 1C:4D:66:47:2D:4D, status: Successful (0), rssi:0
Aug 13 18:41:55 acsd: eth5: selected channel spec: 0x1002 (2)
Aug 13 18:41:55 acsd: eth5: Adjusted channel spec: 0x1002 (2)
Aug 13 18:41:55 acsd: eth6: Selecting 5g band ACS policy
Aug 13 18:41:55 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 1C:4D:66:47:2D:4D, status: Successful (0), rssi:-54
Aug 13 18:41:56 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 64:FF:0A:6C:6D:68, status: Successful (0), rssi:0
Aug 13 18:41:56 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 64:FF:0A:6C:6D:68, status: Successful (0), rssi:-45
Aug 13 18:41:56 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 7C:61:66:B5:C0:EA, status: Successful (0), rssi:0
Aug 13 18:41:56 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind 7C:61:66:B5:C0:EA, status: 0, reason: Unspecified reason (1), rssi:0
Aug 13 18:41:56 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 7C:61:66:B5:C0:EA, status: Successful (0), rssi:-18
Aug 13 18:42:00 wlceventd: wlceventd_proc_event(685): wl0.1: Auth D8:EB:46:C8:7B:05, status: Successful (0), rssi:0
Aug 13 18:42:00 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind D8:EB:46:C8:7B:05, status: 0, reason: Unspecified reason (1), rssi:0
Aug 13 18:42:00 wlceventd: wlceventd_proc_event(685): wl0.1: Auth F4:CF:A2:DD:A6:6D, status: Successful (0), rssi:0
Aug 13 18:42:00 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc F4:CF:A2:DD:A6:6D, status: Successful (0), rssi:-50
Aug 13 18:42:01 roamast: ROAMING Start...
Aug 13 18:42:02 acsd: eth6: selected channel spec: 0xe872 (100/160)
Aug 13 18:42:02 acsd: eth6: Adjusted channel spec: 0xe872 (100/160)
Aug 13 18:42:03 kernel: In wl_dfs_cac_notify_status chanspec 0xe872 DFS state 1
Aug 13 18:42:03 kernel: In wl_dfs_cac_notify_status chanspec 0xe872 DFS state 2
Aug 13 18:42:04 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind D8:EB:46:C8:7B:05, status: 0, reason: Unspecified reason (1), rssi:-57
Aug 13 18:42:04 wlceventd: wlceventd_proc_event(685): wl0.1: Auth D8:EB:46:C8:7B:05, status: Successful (0), rssi:-57
Aug 13 18:42:04 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind D8:EB:46:C8:7B:05, status: 0, reason: Previous authentication no longer valid (2), rssi:-57
Aug 13 18:42:05 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind D8:EB:46:C8:7B:05, status: 0, reason: Unspecified reason (1), rssi:-57
Aug 13 18:42:05 wlceventd: wlceventd_proc_event(685): wl0.1: Auth D8:EB:46:C8:7B:05, status: Successful (0), rssi:-57
Aug 13 18:42:05 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind D8:EB:46:C8:7B:05, status: 0, reason: Previous authentication no longer valid (2), rssi:-57
Aug 13 18:42:05 wlceventd: wlceventd_proc_event(695): wl0.1: ReAssoc D8:EB:46:C8:7B:05, status: Successful (0), rssi:-56
Aug 13 18:42:27 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 18:B4:30:F4:FF:11, status: Successful (0), rssi:0
Aug 13 18:42:27 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 18:B4:30:F4:FF:11, status: Successful (0), rssi:-48
Aug 13 18:42:28 wlceventd: wlceventd_proc_event(722): eth6: Assoc DE:C1:3E:39:C0:A1, status: Successful (0), rssi:-56
Aug 13 18:42:33 kernel: wl0: random key value: 1A96F12BCA446317266400501C0D1D723CEF6C39976E090077FA4CD29D1951A9
Aug 13 18:42:33 wlceventd: wlceventd_proc_event(645): wl0.1: Deauth_ind 7C:61:66:B5:C0:EA, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Aug 13 18:42:33 wlceventd: wlceventd_proc_event(662): wl0.1: Disassoc 7C:61:66:B5:C0:EA, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Aug 13 18:42:37 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 7C:61:66:B5:C0:EA, status: Successful (0), rssi:0
Aug 13 18:42:37 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 7C:61:66:B5:C0:EA, status: Successful (0), rssi:-21
Aug 13 18:43:10 wlceventd: wlceventd_proc_event(685): wl0.1: Auth 30:FD:38:9B:FB:43, status: Successful (0), rssi:0
Aug 13 18:43:10 wlceventd: wlceventd_proc_event(722): wl0.1: Assoc 30:FD:38:9B:FB:43, status: Successful (0), rssi:-54
  • syslog (2) (1).txt
What firmware is the router running?
Post readable screen shots of your WiFi settings, redacting sensitive information, for others to review to see if there are possible issues.
I had a similar issue with 2.4, but only with some laptops, and it was caused by automatic channel selection - when the router switches the channel (in your log, this corresponds to the eth5: selected channel spec: 0x1002 (2) entry), some of the devices, especially if they were in standby mode, could not reconnect. I would start troubleshooting with selecting a fixed channel on 2.4 and rebooting all affected devices.
'Auto channel select' is most definitely a root of your trouble.
