Wifi stops working randomly
mafiaboy01
I'm currently running merlin 380.62_1 on my ac66u and ac56u. The ac56u is setup as an access point and works perfectly.
The ac66u however has been disconnecting devices from wifi. I can still see the network but am unable to connect until I reboot the router. The logs aren't showing anything that would indicate an issue.
LAN and WAN works fine and wired device work without issues.
Have you checked using something like InSSider to see if there are conflicts with other transmitters on similar frequencies?
Yup the network is setup not to overlap. This router is in my basement with very little interference. I get disconnected even when I'm 3 meters away but only happens once a day then I need to restart the router.
I've updated to the new beta firmware and I'll see if that helps.
