A number of routers are now supporting external hard drives with USB 3.0 interfaces. My question is whether that is really worth anything. While, the difference between USB-2 and USB-3 is significant, does it really matter when you are accessing the drive through a wireless router? In other words, since your PC or other device will be accessing the drive over a connection using an 802.11n or, at best, an 802.11ac protocol will the speed of the drive make any difference?
In theory an 802.11n link will connect a device and the router at speeds of up to 150 Mbps (but more likely 54 Mbps) and an 802.11ac link will connect at almost 900 Mbps (maximum), versus optimal USB speeds of: 480 Mbps for USB-2 and 5Gbps for USB -3. Therefore, USB-2 might be a somewhat limiting factor when using an 802.11ac connection but at typical 802.11n speeds it is hard to see what the advantage might be from an upgrade to USB-3.
Am I missing something here?
Thanks,
-Danny.
Thanks,
-Danny.
