Wifi6,dfs
ronorbar
If I don't have 6wifi equipment, is it worth disabling the setting in the router? Another question, dfs setting, in what mode should it be set?
With no AX clients - I would disable AX for better compatibility. About DFS channels - I would use non-DFS channels only for better stability.
For maximum performance regardless of the clients used, leave the WiFi mode to Auto.
Particularly for WiFi certified routers. Anything else will cripple the network over time.
P Does MLO negate DFS channel dropouts? General Wi-Fi Discussion 3
