Recently upgraded from a pair of AX92U's to a pair of ZenWifi ET12's. At first I had them setup in AiMesh, but I didn't like the fact that the 2.4ghz radios on both ET12's were on the same channel...same with 5 and 6ghz radios. So I abandoned AiMesh and just set up the former node as an AP and manually chose different channels. Wifi speeds were ok, but I saw a youtube video where a reviewer was able to achieve almost line speed wifi speed tests (up & down) on 6e.. he's got 1gig fiber. He mentioned he's only got about 30 or so wifi devices connected during his tests. For me however, I've got somewhere between 100 to 120 devices, also with 1gig fiber. Best I was able to achieve was about 750mbps down / 500mbps up with me literally less than 5ft away from the main ET12. If I run the speedtest on the main ET's admin UI...speed test results show around 950+ up/down. Dumb question...would offloading the routing on my main ET router to say...pfSense improve my wifi performance...basically just use both my ET's as AP's? BTW, I use Pihole for my DNS/DHCP services running in a VM. These services have been disabled on my main ET12.
