ByteSlinger
I currently have an ASUS RT-AC66U_B1 router connected directly to my modem. It performs great and reaches most of my house for WiFi.
However I'm setting up a new office room at the other end of my house which in which I'll also be using for VR.
The VR requires me to have a 5ghz router connected directly to my computer via ethernet, and also needs to be in the same room as me and therefore the computer.
My plan is to run an ethernet cable from my existing router into the office room, and straight into either another ASUS RT-AC66U_B1 router or an ASUS RT-AX58U WIFI 6 AX3000 router. Then, connect that router directly to my computer via an ethernet cable, like this:
Now I have three questions on the viability of this.
Firstly, will this work? I know that you can connect an AiMesh node via ethernet to other nodes, but can you still connect nodes to other devices by ethernet or do they just become wifi nodes?
Secondly, when connecting to the VR with this setup, what rout would the data take? With the headset connected to the router in the study and that router connected straight to my computer logic would dictate that it would all communicate directly, but as this node would be set up just as a node, would everything still be bounced down from the primary router?
Finally, would there be any notable impact on general internet performance as a result of being accessed via the node router rather than directly from the primary one?
Thanks all
Thanks all
